Is it possible to replace MAF's thermistor?
Hi everybody,
I am new to the forum, not to the website anyway...precious resource, thanks.
My MAF's (13800-58B00, Vitara 1.6 16v) thermistor has been blown away, because of an LPG backflame, I guess. Given the price of the good MAFs, I would like to ask you if you think it is possible to replace the thermistor only, and, in this case, where can I find its specifics.
Thank you!
impossible
there is no spec. on it or source.
ouch flame back failure, sounds like too lean.
how can LPG run with a stock ecu and MAF, impossible. that.
my guess is car is dual fuel setup. and the LPG side blew up the Gas side, dang that is a first here... sorry it happened to you.
buy a used maf of fleabay is best change, and not the clone its no good.
the get harder an harder to find
or buy the CARDONE rebuilt. for 1/3 suz. price.
Thumbs Up
Yes, it is dual fuel. I will follow your advice, then.
Harder and harder to find, you're right!
Thanks again
(09-15-2015, 12:59 AM)fixkick Wrote: impossible
I got brand new mass airflow sensor OEM mitsi product here in nz for $300Nzd all up there must be some auto electrical place that sell OEM ones over there
5 times cheaper that here.! 192USD
over $1100 USD here. (suzuki sales counter)
but we have good old CARDONE that rebuilds them... and 100% tested.
the insides are not documented, it's a Mitsubishi secret.
china tried to do it and failed.
here is the china hack job. (revealed)
http://www.fixkick.com/sensors/china-maf...d-maf.html
as you can see the thermistors are factory trimmed, "calibrated" so replacing one, would need to be re calibrated.
this schematic is not from any Mitsubishi.
