ECU question
93 kick , 1.6L , 16V , 5speed , Thorley header
What is the first indication the ECU is starting to fail?
Lon
that is a very good question.
1: stalls.
2: CEL goes dead keyon. check engine light.
3: fuel pump fails to run for 3 seconds key on.
4: acid leaking out the bottom of ECU (LOL) but is true and common. 1/2 joking.....
5: while in diagnostic mode code 12 flashing the flashing aborts MID STRIDE , this is ECU crash, (bad caps is top reason)
6: if you had a scan tool and it was connected, the link would do dead, randomly , comm. fails.
7 SOME ecU with dried out caps, you hit a bump (speed) and the cap shorts a moment and car stalls. seen many do that. vibration sensitve, the alum, foil in sidethe cap can short, some even explode,and crack the case wide open (I have a collection)
always pop the lid and look for the green slime of death, leaking caps.
they all do that 1989 to 95, and never after that year. at least 1 time.
put my Nichicon cap's in there and will last for ever. near.
see the 8 tests.
see the Nichicon at end.
http://www.fixkick.com/ECU/ECU.html
1993 kick 1.6l 16v 5speed
I have gotten the computer out.
It is Mitsubishi , 33920-58B50 (or O)/E2T42071 T / 2608 U1 .......(cal-MT) Is this the correct ECU for my kick?
Can only find 2 electrolytic capacitors ....C103 and C101.
C101 IS leaking , could that be the cause of the INTERMITTENT low speed miss?
Lon
c101, sure.
here is the suzuki official ecu page for usa and canada. world wide , huge number of types,
is it black that cap? and does any say rubycon?
id replace them both. the dry out , some do with no external warnings, bulges ,cracks or leaks.
58B50 is Calif, rules, 16v M/T ECU 1993 so is a match.the under hood sticker might say, compliance USA fed and calif regs.
for sure leaking is a bad sigh, very bad, if the traces are not eaten to nothing, your ok, just replace it, its polarized. long bar strip is Negative.
im not sure what 101 would upset, but am 100% its not a good thing,, after all noise can cause crazy things to happen in digital and analog electronics
in fact that is #1 to all board tech',s NOISE tests on power.
1:visual
2: get new caps on old boards."electrolytics" many now are already replaced, most long ago gave up the Rubycon ghost.
3: noise tests
4: full testing. (logic, vibration and thermal cycling)
i think there are only 2. caps
http://www.fixkick.com/ECU/ECU16v_92-95.html
the others are good for long haul. real long.
electrolytic are the Achilles heel of electronics. (the stories, are endless, here, ) back in the TUBE days, 10x worse for heat.
i did see a 20 year old ECU new in box, and the caps were good, proving to me ,that heat is the killer, never seen a good used (RAN)old Rubycon yet.
only the unsoldering is hard.
takes TLC, and skill. (not overheating pads etc)
i think a new front crank bolt
and new caps up to 1995 , are the top fix on this car.
best bang for buck long term. ($10 + $3)
Users browsing this thread:
