EGR Valve Probes still available?
Fixkick,
If you purchase one of these EGR valves on Ebay, can you still buy the electrical probe for it? I haven't seen the probe sold.
http://www.ebay.com/itm/EGR-Valve-ACDelc...72&vxp=mtr
Not sure if this aftermarket fits....
http://www.ebay.com/itm/Standard-Motor-P...d2&vxp=mtr
This maybe suzuki part num?
http://lehmansuzukipartsonline.com/parts...eid=216897
most used probes are good. it just a resistor, and crude..
just take out the old one. (heat casing hot, then take it off it tight. (for 80 to 160 bucks , i even split the old casing, to free it.) the test is easy, for ohms.
sure they are available but very expensive
all 89-95 are same. pn usa, canada and Caribbean
18216-56b00
did you look at rockauto first?
bingo , 3 makers +1 suzuki = 4
GM shows, Discontinued .
http://www.rockauto.com/catalog/raframec...ttype=5093
Fixkick
What's the proper way to seal the probe to the egr valve? Should some sorta compound be used or should it be threaded in dry?
id use, antiseize on it so in the future,it might come one, some wont.
