A/C leaking at the compressor manifold
Put U/V dye in and it appears that my freon leak is between where the hoses attach to the top of manifold (3) and the manifold to the compressor (2). Do you have any information about the size of the O-rings inside the manifold and especially the rectangular O-ring (6)between the two pieces of the manifold? P/Ns?
suz p/n
3=95254-82000
5=95259-82001
both are listed here
shows no size, sadly
hope that helps
