crankshaft cog question
Hi everyone, just want to know will a 96-98 1.6L 16V crankshaft cog fit on a 1999 1.6 16v. If not where could i find a new one, can't seem to find one.
Thanks in advance....great site
(11-13-2019, 04:04 AM)wamster Wrote: Hi everyone, just want to know will a 96-98 1.6L 16V crankshaft cog fit on a 1999 1.6 16v. If not where could i find a new one, can't seem to find one.
2 questions that will cost you... Tongue
q1: where to buy , only suzuki and GM-GEO sells them new, used on ebay,
q2: years fit same,, ok will lock now.... in the ECP. (cat)  answering for usa and tracker /sidekick only
a2: shows all the same up to 2003 G16b.  (not Esteems that have G16 too)
the number of teeth are not the same on some G16 esteems is one.
the PN is 12630-57B01
east coast suzuki
they now list parts with wrong names,  the esteem 99 uses same prefix but 52G00 end.  suzuki is really messed up now.
from good to bad to now ugly.
here it is listed as a timing gear
suzuki deleted the parts diagrams, wow.
gm geo, chevy tracker, 1999,  same part
i think is GM Pn  9606-8590 ( NO)
and at one point GM changes P/N radically so some of old lists are now wrong. (dirty trick that)
Bingo: but not stocked.
the correct GM part is here,  on site that shows actual drawings, crank ID: #24 is crank cog wheel. tone wheel is what it really is.
Crankshaft Gear - GM (91173455)
says fits some metro's G10 ? 1L
Also you could try https://trailtough.com/ if you are in the states.
