Post Reply
  • 0 Votes - 0 Average
how to fix rocker panels ?
07-29-2017, 04:09 PM
Post: #1
A rocker panel is a stamped steel piece that is an integral part of your car's body structure. Rocker panels are located along the sides of the vehicle between front and rear wheel well openings, just below the doors.If your rocker was originally secured with spot-welds, use a spot-weld bit to cut them out. Use a cut-off wheel on your angle grinder to carefully remove the remaining rusted or damaged rocker panel. here
Find all posts by this user
Quote this message in a reply
07-31-2017, 01:14 PM
Post: #2
RE: how to fix rocker panels ?
When you are talking angle grinder, it becomes dear to my heart.
My advice is to shop around
10-02-2017, 02:38 PM
Post: #3
have you found the solution to this?
Post Reply
User(s) browsing this thread: 1 Guest(s)
