Post Reply
  • 0 Votes - 0 Average
Idles, but dies giving throttle
07-20-2017, 10:53 AM
Post: #1
Just scored my first Sidekick!
1993, 4 door LX 16V. Pretty good shape, except no spark when I bought it ($400USD).
New igniter, replaced all underdash fuses, checked dist cap, rotor, connections, etc. Got it to run when trying rotor in all 3 positions.
It idled at around 3,000 rpm, and would immediately die with throttle opened. Literally could push throttle to floor and hold it, no RPM increase, just died like ignition turned off.
Checked throttle body (clean, no damage), installed TPS from a known running vehicle, set .026 gap at screw with DMM, reinstalled - no change.
Pinched IAC hose tight, it idled down,(YAY!) and got to around 1,000 RPM or below via bleed screw.
Checked hoses, tried propane torch (not lit!) everywhere reachable on intake side, no changes in idle.
Starts easy enough and idles with IAC pinched.
Still dies when opening throttle, though.
I just pulled the IAC to inspect and clean.
Am I on the right path? Pointers?
Thanks so much. Really appreciate fixkick.com and this forum. Wealth of information!
Find all posts by this user
Quote this message in a reply
07-20-2017, 11:26 AM
Post: #2
RE: Idles, but dies giving throttle
that is a bad rotor from china.
a real rotor CAN NOT TO THAT
it has steal spring clip in the bottom that blocks that (the new car had mitsubishi rotor) and it too does not plant 3ways
the bosch page on same rotor says,"fits just the the original 1 way" they too know what china ,knockoff crap does. what pain.
IAC, the electric one or water only one.?
water IAC is below TB
electric is more front on left side of plenum box, i call it ISC, to make it unique name.
you are on good track for sure... all that.
the high idle.
what is idle with ISC electric connector pulled.
400 is typical or you have air leaks.
sure clean the iSC
make sure the EGRs does not suck air,missing gaskets, are common there.
pinch all vacuum hoses.
IAC stuck open , below Throttle body or the water hose, is blocked
make sure water temp goes to 180f, the IAC closes at 150f so, is 100% closes past 150f.
cold idle is about 1500 rpm and winds down to 800 slow as water gets hotter.
hot is 800. ac off
ac on 1000 hot.
sorry you got ROTOR'ED!
cheers.
http://fixkick.com/
07-20-2017, 12:13 PM
Post: #3
(07-20-2017 11:26 AM)fixkick Wrote:  that is a bad rotor from china.
the high idle.
sure clean the iSC
hot is 800. ac off
ac on 1000 hot.
cheers.
Thanks so much for the super quick reply!
ISC is electric. It's off the car now for cleaning. Will check EGR and idle with ISC installed but unplugged wires.
Couldn't find your page on how to clean ISC?
07-20-2017, 12:57 PM
Post: #4
the high idle.
sure clean the iSC
hot is 800. ac off
ac on 1000 hot.
cheers.
OK - didn't clean ISC (couldn't get tubes to pull out after removing screw) so reinstalled with RTV just to test.
Still high idle unless pinching ISC air hose, *NEW INFORMATION: AND idle drops just fine when ISC wires are unplugged!
I pinched every hose which is visible, without affecting idle speed.
And it still completely dies when opening throttle. It is possible to raise RPMs a bit if throttle is opened a bit, very slowly. But it won't even pull its own weight on level ground.
Just seems like it is not getting needed fuel as it comes off idle.
07-25-2017, 08:34 PM (This post was last modified: 07-25-2017 08:34 PM by fixkick.)
Post: #5
we need to start over.. my guess this is what is called a barn find car. (not a daily driver for years. i bet)
so it starts now. how old is the fuel, or how old was the fuel as you got it ? old fuel goes bad, and when it does the injector screens clog. 10 micron size screens 4 times smaller than the filter.
i think idle is last, it always is, all must be good for the engine ecu to regulate idle properly (many thing)
so
key on ,CEL must glow, if not fix this first. many barn cars have the lamp removed or taped black .
then insert the diagnostic jumper. in to the DLC jack near the battery.
key on it flashes 12s start engine , sill 12s.
the DLC is here.
id have done a compression test day one, to see if the engine has a future. for sure.
compression testis here.
zero power based on all normal causes are:
1: lost compression , eg: 80psi (not 180 normal) is cam belt slipped. as all do after 60k miles. , tool. is a compression gauge.
2: low fuel pressure. (one more guage)
3: maf bad or just dirty. (look for DTC codes first bad maf)
4: injectors clogged.
5: someone played with the distributor and set timing way off, or caused by cam belt slipped, best is to do #1 first and not try to fix spark until cam is set right. or make it worse.
6; bad fuel. (barn found cars sure)
easy has test. we can to them and there is page for each
idle corrected last. (its like, deck chairs on the titanic, not arranged properly)
good luck.
http://fixkick.com/
10-04-2017, 02:10 PM
Post: #6
have you managed to fix the idle issue?
10-04-2017, 09:44 PM
Post: #7
(10-04-2017 02:10 PM)Samoo3 Wrote:  have you managed to fix the idle issue?
car bought dead.
can be lots of causes.
but starts now....
zero power. ( can be, cat melted and clogged, compression pathetic, MAF dead, still no check engine flash codes reported , got 12s' why not use the jumper clip and read the flash codes from the ECU.
too fast idle , ISC unplugged tell me ECU is in limphome mode, and idle has nothing at all to do with this, its only a VICTIM of other majore causes.
we start a the engine,, compression test , the tool is $20 , all shops have one, if not you chase tail for days,
the EFI system can not run a dead engine, is why we do that, and is called checking basics first.
the engine must breath, must not have melted cat, blocking engine exhuast.
the compression is 180 PSI if 80, x4 , the belt slipped on the cam. or worse. the readings on all 4 matter, exact readings WOT, wide open throttle.
Then spark is next did the last guy play with the destributor ,finds spark way off time from above and then tried to correct it not fixing above line first.
Ok sparks good, next is what (MAF)
the paper clip test, we insert it , key on see flash codes. got non 12's??? if yes what.? then start engine, got 12s still?
http://fixkick.com/
Post Reply
User(s) browsing this thread: 2 Guest(s)
