Threads: 2
I'm looking for valve lifters (rocker arm adjusting screws) for my 96 tracker. The only thing I can find for the intake rockers is 96 sidekick at suzukicarparts.com They both are 1.6l 16 valve heads. Does anyone know if they are the same? The Suzuki part # is 1284661D00 for the sidekick and 96068601 for the GEO.
Threads: 2
Do you know where I can get the intake rocker arm adjusting screws for the 96 Geo Tracker?
Threads: 3
If you just need the adjusting screws, you can fab them from good quality bolts
the screws are not simple screws
there are case hardened , and very special for this purpose.
and metric.
Threads: 2
The screw in your picture is for the exhaust valve rocker. I need the intake valve rocker screw. It has a ball end that rides in the rocker rail.
Threads: 3
And it hangs on a spring, but I'm not about to give mine up. What happened to the ones you have?
