Post Reply
  • 0 Votes - 0 Average
Wires for transmission
06-25-2017, 11:50 AM
Post: #1
I can't find where they plug into it . Swapped out a motor and transmission from an original automatic put it in what was originally a 5-speed but cannot figure out where the wires plug in on the transmission I think it's a SLR plug tcc plug
Find all posts by this user
Quote this message in a reply
06-25-2017, 10:52 PM
Post: #2
RE: Wires for transmission
i cant understand what you had before and now. (seems A/t OVER m/t CAR) BUT WHAT A/T? THE gm 3L30 or the aisin box 4speed 03-72LE ? there are 3 transmissions used,
the car has many harnesses,
there are 3 in this case.
5speed stick
4speed AT
3speed AT
all 3 are different and the front A/T cars have the TCC lockup solenoid. up never rigtht front finder only seen on 3speed AT
the 4speed TCM brain under dash runs all solinoids even the TCC locker.
5speed has none of that nor the 5speed of the range selector switch
is car 4wd?
the 5speed has reverse switch only, all have a 4wd switch if it is 4wd.
TCC, all ways there was for 10 years.
http://www.fixkick.com/tranny/automatic-...tml#4speed
the 4speed box looks like this , see the side plate, there are lots of 3speed photos too, and all TSB sheets. there.
http://www.fixkick.com/slush-pump.html#4speed_fast
http://fixkick.com/
06-26-2017, 02:49 AM
Post: #3
Change my 94 over from a straight shift to an automatic finally got all the plugs plugged up found the missing one but now have no fire
06-26-2017, 03:40 AM
Post: #4
5sp to what,. 3sp , or 5speed.
there 3 cars, there, and 4wd too.
what do you have now./
what engine, 8v or 16v
8v is TBI
16v is MPI
key cel lamp on , must be or fuses blown and ECU dead lack of power.
CEL glows
no fire, means to me i cranks ok
so did you insert the diagnostic jumper sand see if you get DTC errors after cranking a dead engine , code 12 flash code means it things all is ok.
got spec fuel pressure
does it run on spray test fuel
if not is there spark>?
i sparks dead x4 then the Distributor connector side , fell off?
or is time radically wrong?
http://fixkick.com/
06-26-2017, 03:44 AM (This post was last modified: 06-26-2017 03:48 AM by fixkick.)
Post: #5
The transmission was 5speed manual stick shift as you said Straight shift,
so if the old trans 5sp is gone then the clutch switch pedal is now gone, right?????
the if the pedals is gone? then the clutch switch is now gone! and the starter is now dead, on all 5speeds stick shifts made.
The 5sp uses a neutral switch on the clutch, (you must step on the clutch to crank any sidekick made, 5sp)
when you put in an auto box, that PRNDL switch needs to be wired to the old clutch switch or the car will start in gear. bad idea that. (ok for me but not kids , not wife, kids means teen driver) Btw I owned many car in 1965 and all started in gear>...so its not an issue for me, personallY)(
engine don't run, now.
so why not work that first?
step 1, cranks? yes/no
step 2, no !, fix clutch switch PRNDL rewire fix.
step 3, it cranks,ok good.
step 4 for does test fuel work, (spraY)???
step 5, no, sparks bad.
step 5a yes, fuel pressure is zero. (and more ask, 3 things cut fuel)
http://fixkick.com/
Post Reply
