Threads: 36
The worldwide site lists the AC condenser for Sidekick Sport 95310-58B50 CONDENSER V:SE416 and 95310-77E50 CONDENSER V:SV418. So it looks like the AC condenser for 1.6l fits 1.8. The rockauto.com lists the AC condenser for the Sidekick Sport 1.8 fits 1994-1998 Sidekick. Therefore, it looks like the AC condenser of the 1.6l Sidekick fits the Sidekick Sport 1.8l??
(09-11-2019, 06:48 PM)rasmeidirt Wrote: The worldwide site lists the AC condenser for Sidekick Sport 95310-58B50 CONDENSER V:SE416 and 95310-77E50 CONDENSER V:SV418. So it looks like the AC condenser for 1.6l fits 1.8. The rockauto.com lists the AC condenser for the Sidekick Sport 1.8 fits 1994-1998 Sidekick. Therefore, it looks like the AC condenser of the 1.6l Sidekick fits the Sidekick Sport 1.8l??
remember I told you many parts makers and stores. dont even ask if the car is J18 or SPort,, ADP/PRO home page does the same dirty thing. you need to learn this first.
do forget buy parts on SIDEKick not from SUSUKI actual, can be very hard.
The A/C is also and addon option, some dealers , get cars with NO AC and then put in a 3rd party system. I told you I cant see your car so how would I detect that?
the SPORT is only sold in USA and Canada and most are made in the CAMI plant in Canada for this N.American market
so that means cars sold outside USA are not SPORT model.
The AC system chosen by CAMI is what they picked, there. in that Assembly plate in Canada.
why would you think that, , the sport j18 is wide frame car,
not only that but the condenser comes in 2 sizes, one is 2door and other is 4 door,
the 58b50 fits only the 92-98 se416 body, called sidekick (non-sport)
the SV418 (SV means sport) 2door ends in 67A50
the SV418 4door is 77E50 .
now you ask me why rockauto gets this wrong/ ? im not them ask them for help or read the page there, at rock and read the makers name, then read their online catalog.
The G16car radiator is
why not have signature?
like this,
"1996 Suzuki Sport J18, 4wd,4doors,4speed A/T (usa car/in/Vietnam)" (please correct this or fill out your profile with that and your VIN number.
parts are not easy to find , for this old car for sure SPORTs (very few sold and still running)
The G16 condenser is 371.5mm high and 447.7mm wide
by fit , we men 3 things,
1: fits the mounts in the sport frame.
2: fittings fit, all the AC lines fit and line up.
3: and is large enough to cool the 4door inside, (is it 4doors?) most are but is it?
I could not find the spec on j18 condensers. (size and all that) 95310-77E50
i searched the EPC (electronics parts catalog SUZ) for 77E50 and it shows just one car. 4door sport. J18. no other car uses it world wide, suzuki.
what that means IDK.
one top maker in usa, for condensers and radiators and gas tanks is Spectra-Premium.
https://ecat.spectrapremium.com/products/7-4624
there really is many sizes based on these facts.
door count
sport j18 body wide frame) Wide frame, lets even V6 engines fit now.
non sport G16 body narrow.
and fittings, the condenser has special fitting for the Receiver dryer.
Nippon Denso (no called DENSO) sells them too in japan but does not list J18;.
i went to the top 5 stores here online not one sells this part. (g16 yes some)
only rock lists it. and does horrible job, doing so, not asking if car is SPORT.
the standards for measurement are hard find, L/W
most only measure the actual core only, as frame brackets vary so, they do core is stated. (BEST i CAN TELL)
So measure your core first, I SURE WOULD.
Threads: 36
09-12-2019, 03:37 PM
(This post was last modified: 09-12-2019, 03:40 PM by rasmeidirt.
Edit Reason: Not seeing the attachment
(09-11-2019, 11:40 PM)fixkick Wrote: one top maker in usa, for condensers and radiators and gas tanks is Spectra-Premium.
door count
This is my 96' Sidekick Sport OEM AC condenser look like.
Threads: 36
(09-12-2019, 03:37 PM)rasmeidirt Wrote: (09-11-2019, 11:40 PM)fixkick Wrote: one top maker in usa, for condensers and radiators and gas tanks is Spectra-Premium.
door count
The Sidekick Sport 1.8 OEM AC condenser.
Threads: 36
(09-16-2019, 05:46 PM)rasmeidirt Wrote: (09-12-2019, 03:37 PM)rasmeidirt Wrote: (09-11-2019, 11:40 PM)fixkick Wrote: one top maker in usa, for condensers and radiators and gas tanks is Spectra-Premium.
door count
It is
Threads: 36
09-16-2019, 06:07 PM
(This post was last modified: 09-16-2019, 09:02 PM by rasmeidirt.)
(09-16-2019, 05:51 PM)rasmeidirt Wrote: (09-16-2019, 05:46 PM)rasmeidirt Wrote: (09-12-2019, 03:37 PM)rasmeidirt Wrote: (09-11-2019, 11:40 PM)fixkick Wrote: one top maker in usa, for condensers and radiators and gas tanks is Spectra-Premium.
door count
It is
https://imgur.com/P03OthM
So far I cannot find any condenser to make possible mods to fit the old one. Maybe cleaning the old one with air conditioner solvent and use it again??
Threads: 36
(09-16-2019, 06:07 PM)rasmeidirt Wrote: (09-16-2019, 05:51 PM)rasmeidirt Wrote: (09-16-2019, 05:46 PM)rasmeidirt Wrote: (09-12-2019, 03:37 PM)rasmeidirt Wrote: (09-11-2019, 11:40 PM)fixkick Wrote: one top maker in usa, for condensers and radiators and gas tanks is Spectra-Premium.
door count
It is
So far I cannot find any condenser to make possible mods to fit the old one. Maybe cleaning the old one with air conditioner solvent and use it again?? Cannot find the one similar to mod of the condenser!
Decided to clean the old one with the air conditioner cleaners for inside (the two ports) and outside (the fin) to use again. I changed the drier and the compressor (4seasion 78491 purchased on rockauto.com. It is really fit the Sport).
(09-18-2019, 10:28 PM)rasmeidirt Wrote: (09-16-2019, 06:07 PM)rasmeidirt Wrote: (09-16-2019, 05:51 PM)rasmeidirt Wrote: (09-16-2019, 05:46 PM)rasmeidirt Wrote: (09-12-2019, 03:37 PM)rasmeidirt Wrote: This is my 96' Sidekick Sport OEM AC condenser look like.
It is
any car this old and 10,000 miles from home, USA)
only AC shops can fix cars, lacking OEM partsl. ok?
In many cases custom retrofitting parts. (hacking and the like)
Do not run the AC with the hi/lo switch bypassed or you will wreck the system. ok?
Threads: 36
(09-19-2019, 12:54 AM)fixkick Wrote: (09-18-2019, 10:28 PM)rasmeidirt Wrote: (09-16-2019, 06:07 PM)rasmeidirt Wrote: (09-16-2019, 05:51 PM)rasmeidirt Wrote: (09-16-2019, 05:46 PM)rasmeidirt Wrote: The Sidekick Sport 1.8 OEM AC condenser.
It is
Do not run the AC with the hi/lo switch bypassed or you will wreck the system. ok? No, the shop! I have no equipment for that.
