Threads: 4
Mine is also 4x4 forgot to add that.
Also i thought about dropping the rear trand support but realized that you must drop the exhaust too.. i chose to leave it in. My exhaust header back is all brand new. With that in mind i still didnt want to mess with it... couldn't imagine old crusty rusty exhsust trying to remove it.. nope
10-17-2018, 03:29 AM
(This post was last modified: 10-17-2018, 03:41 AM by fixkick.)
ah yes, 4wd makes it harder, with 2 prop shafts and lower any tranny with those connected.
yes, the exhaust is in the way, on some.
yes , working on AT boxes, in car, is super hard. 4speed worst.
I hope your leaks all stop, and are easy to fix. (cheers to you)
and thanks a million for photos' others will love seeing how hard this can be. just a cable.
that why, they can plan ahead, that sure is a tight spot to work.
Just fixed my jeeps, steering wheel clock spring after the recall guys broke it (DANG). $700 dealer fix, me fix $100 (HOW CAN THEY CHARGE $600 FOR 1 HOURS LABOR/?)
They earned stealership moniker.
Threads: 4
Well i gave it alot of time this time.. im officially calling it! The leak is gone! It was the damn o ring on the kick down cable this entire time! Well now i can finally move on to the next issue. Theres alot that needs mending.
great to hear !
those AT boxes can be super hard to seal up, some even have casting flaws. (GM are noted for that)
happy trails and cheers !
