96 tracker o2 sensor
what's the easiest way to get to the downstream o2 sensor plug? I assume its in the center console somewhere.
02 rear, cable goes up, and through hole just above,, under driver seat and under carpet,
what you mean plug, Grommet?
Yeah, it's under the drivers seat. Just remove the grommet from underneath & the connector is a couple inches up the wire.
sorry, i did not know you were asking how to unplug the O2,
sure, under the see, if you follow the wire, you will land to the connector.
as you can see ,dry , rust free connections are best. and under seat, too bad the ones behind the left rear tail light cant keep dry,
