Vw 1.8l turbo motor swap
Ok,I know they make kits to do these swaps. BUT ,here's my question(s). Acme website says 98 and older jettas,past ect....and newer beatles, wouldn't the newer beatles have ecu's that would need to be swapped also? And if it's the same 1.8 that's in the jetta,why can't you use it? I'm asking bc I'm considering doing this swap,since I've already got my motor out and I would like to have more power, I want to do a gas turbo 4 cylinder,keep my transmission and 4x4, I like having 4x4 for the occasional snow we get . I know this subject has been BEATEN TO DEATH. We know the engine fits, its swappable, BUT if I do this will I need a stand alone ecu, or will a newer 1.8's sensors be able to talk to my ecu on a 96 tracker?
The basic concept of an engine swap is installing a large engine into a small car in the hopes of having a vehicle with a very high power-to-weight ratio. Usually this means creating a vehicle configuration that is not factory original. Much of hot-rodding's history comes from engine swapping.
[url=http://www.clazwork.com]best essay writing service[/url]
How do I get to the last read post in a topic or perhaps that should be the oldest unread post like I was able to in the old format?
[url=http://tvoydosug.com/fashion/ukrainian-girls-best-photos.html]Single ukrainian girls[/url]
